Help---D16Y7 exhaust to D16Y8 style exhaust
I have a 1997 Honda Civic LX sedan with a pretty much stock exhaust. The exhaust manifold has a crack running down the center of it to the O2 sensor which I read online is a common problem. I would like to replace the stock manifold with 4-2-1 exhaust headers and a new catalytic converter (as the current one is old and rusting). My problem is that the D16Y7's exhaust manifold and cat are one piece and I'm concerned that if I use aftermarket headers and cat that it will not fit right with the stock resonator pipe and muffler. Does anyone know if moving the cat to the underside of the car like this will cause space issues? I know this is an issue for hatchbacks of the same year but don't know if it will be a problem with my LX. I need to have a cat to pass emissions tests. Anyone done this?
Re: Help---D16Y7 exhaust to D16Y8 style exhaust
You can relocate the cat with a new header/exhaust setup but make sure you have a bung for the O2 sensor before the cat
Agree^
you'll also need to extend the wires should you do that. It's called a header* not "headers" this in an inline 4 not a V6/V8...
hatchbacks are shorter. just buy everything to fit a 4dr EX- manifold, cat. cov., B-pipe and as was mentioned extend the O2 wires to fit the new location.
The Grumpiest
This is simple. Get everything from an EX. Everything you have on your car now has an EX version; header, cat, catback. You want the EX version of these components. I mean everything. Get an O2 wire extender for Hondarpartshero's Ebay store so it's plug and play. I really don't know why this seems to be a difficult concept to grasp.
Thanks everyone. Glad to hear I won't have to cut and weld extra pipes (seeing as I don't weld that would cost me a bit). Didn't want to get everything and realize it wasn't gonna fit. Thanks for the replies
