HELP: Cluster doesnt work and turn signals don't work
I was driving my eg6 one day and my cluster shut off while driving and then i also found out that my turn signals were not working. Then I found out that the back up fuse was blown, I switched clusters and replaced the fuse and it still blew. My right rear taillight was busted and water could have possibly ****ed with the harness for the rearlights, So could replacing that specific harness remedy the prob ?? ANY HELP is Appreciated.
Re: HELP: Cluster doesnt work and turn signals don't work
does your cluster still work? also the harness should be fine thats why all wiring is fused so if the amperage is exceeded the fuse pops and there for the wiring is ok. You say your back taillight is broken did you check the bulb holder it self to see if any water has accumulated near or on it? also check the wiring that is available to plan view to see if there are any nicked or open portions on it. Also check the correct bulb is installed and correct fuse.
I just remembered that when i put my car into accessory the battery light comes on, hmm thanks for the advice ill check it out, thanks.
I figured everything out, thanks a lot davedomonkos, it actually was the rear harness thats connected to the rear tailight, turn lights and reverse light was corroded due to exposure to water, went to the scrap yard and picked up a new one and attached everything is working proper now. Thanks a lot
akcapr
11
02-27-2011 09:55 PM
EGed up from the seat up
03-04-2009 04:13 PM
EKstasy
06-18-2006 12:32 PM
