Help! Been battling this stalling / surging problem forever! 95 civic dx
Old 10-27-2015, 07:03 PM
Davethegreat's Avatar
Default Help! Been battling this stalling / surging problem forever! 95 civic dx
Hey guys so I've been having this consistent problem lately. My vehicle comes raddles and shakes up at stoplights, sometimes in idle, and such. When coming to stoplights I gotta put my baby in neutral so it doesn't stall out on me. If it stalls the following startup is inconsistent. At times it'll start up with no problem then other times it'll be a long crank then finally starts up. I've done a shitload of things with some help from my last thread but I've been busy fr a while so I kinda stepped away.
These are the things I have done:
Replace Icm
Replaced fuel filter
Replaced ignition coil
Complete tuneup
Cleaned iac valve
Cleaned throttle body
Checked for vacuume leaks and none
Replaced o2 sensor
Replaced car converter however those 2 needed to be replaced . Used fuel injector cleaners
Wondering whT else I may possibly do im out of ideas
Ordered an eBay tps for $10 gonna see if this will work.
A while back I read my codes and had a code 41. Primary oxygen sensor heater. So wondering if that has anything to do with my surging issue. Any ideas suggestions or help appreciated !
Old 10-27-2015, 09:19 PM
Hookers and blow
dipsy's Avatar
Default Re: Help! Been battling this stalling / surging problem forever! 95 civic dx
Replace Icm
Complete tuneup
Cleaned iac valve
Replaced o2 sensor
Old 10-27-2015, 11:16 PM
Slain's Avatar
I know you replaced the ignitor and coil.. but how did the connections inside the distributor look ?
Old 10-27-2015, 11:25 PM
Connections were fine no corrosion no nothin.
Old 10-28-2015, 12:44 AM
Steve at Heart
Bently_Coop's Avatar
Is the distributor red inside? Why didn't you post in the tech section? Do you like peppered angus?
Old 10-28-2015, 02:27 AM
Drunk Wagon Pilot
Pinja's Avatar
Replace Icm
Complete tuneup
Cleaned iac valve
Replaced o2 sensor
lmfao
Old 10-28-2015, 02:35 AM
If you loved me, you'd all sell me your magic cards to me today
doctorake's Avatar
Have you checked the differential sensor?
Old 10-28-2015, 06:55 AM
Honda-Tech Titanium Member
mozzandherb's Avatar
My vehicle come raddles and shakes up. I gotta put my baby in neutral
Old 10-28-2015, 07:17 AM
MEAT PATTY
goforbroke's Avatar
The obvious question: are you throwing any codes?
Did you use a timing gun?
The gangbang is coming.
Old 10-28-2015, 07:25 AM
acmoc's Avatar
timing seems off
Old 10-28-2015, 07:31 AM
doctorake's Avatar
Old 10-28-2015, 07:57 AM
No Big Whoop
Spaceballsthelunchbox's Avatar
Take it to a competent mechanic.
If your ability to work on cars is congruent with your ability to post in the correct forum, you are hopeless.
Old 10-28-2015, 08:12 AM
I like to party
2LEM1's Avatar
Don't worry, the type of car, motor, or any mods done aren't relevant information anyway.
Old 10-28-2015, 09:13 AM
kenji's Avatar
2LEM1 has a good point. What year engine? What year car? Which ECU?
-Kenji
Old 10-28-2015, 09:38 AM
My Name is Nobody
MSchu's Avatar
does this car have a MAF or MAP?
Old 10-28-2015, 09:49 AM
CRX God
whited's Avatar
I think you need to replace your Kuhneutson Valve
Kuhneutson Valve - $20.00 : KaleCoAuto.com, Your home for the rare, unusual, and hard to find auto parts.
Old 10-28-2015, 09:52 AM
doctorake's Avatar
Jack the car up and look under the transmission, there should be a small red sensor there, make sure it is plugged in.
Old 10-28-2015, 01:16 PM
It has a map sensor which I've already replaced as well
Old 10-28-2015, 01:17 PM
Yea timing gun was used . The timing is correct, I have codes 41 and 13
Old 10-28-2015, 01:21 PM
No where is this located
Old 10-28-2015, 01:24 PM
I never narc'd on nobody!
NotARaCist's Avatar
Why the **** is this in GDD, and why did you scroll right past tech to post it here?
Old 10-28-2015, 01:26 PM
Dragon Slayer For Hire
srd....'s Avatar
Get rid of it for a car that isn't going to also be a money pit srs.
Old 10-28-2015, 01:37 PM
I said I don't want a title!
Todd00's Avatar
PM user "tw1tch". He has a buddy that knows a good mechanic.
Old 10-28-2015, 01:51 PM
doctorake's Avatar
Old 10-28-2015, 04:03 PM
delsolintegra's Avatar
Replace the coolant temp sensor, about a $20 - $28 part.(Autozone)
I bet it has finally failed and your ECU thinks it is always managing a cold engine. The result is fuel ratios and timing are slightly off.
Cold engine starts are fine. Warm engine starts are bad if at all because too much fuel is being delivered (the ECU thinks it is starting a cold engine and is dumping too much fuel)
This problem will not give you a cel. The car will run like crap.
I have been there with my 93 del sol si.
Quick Reply: Help! Been battling this stalling / surging problem forever! 95 civic dx
