HELP with b18c1
HELP with b18c1
i recently got a 00 ex coupe, and want to swap mi d16y8 with a DOHC but am having trouble picking one out. I dont really want to do with a b16, thought about an h22, but i was curious to kno if a gsr motor will be able to fit into mi bay. what wouold it take for it to happen if possible? do u guys have any other ideas about what motor i should drop in or what i should do at all. I have seen SOHC engines boosted but thats not what i want to do. THANKS
what you will need:
Mounts
99-00 SI driver side motor mount bracket
99-00 SI Rear "L" bracket
the rest of the mounts and brackets will work
Wireing
use ur civic harness and modify it to fit (if u want it to look stock, take ur stock harness and rip off all the black stuff covering the wires and plug it all up on the b18c...this way u dont have to cut and splice wires...now the wires that still dont reach, just cut, solder, and heatshrink...after ur done put all the black covering back on and use electrical tape and take it all back up nicely.)
Staying JDM or USDM
JDM - if ur gonna stay JDM u DO NOT need to hook up secondary o2, Evap purge solenoid, CFK
USDM - YES u will need to hook up everything
and yes any b series will fit into ur bay
Mounts
Wireing
Staying JDM or USDM
cute little bastard
Re: HELP with b18c1 (SmYrE)
Re: (JDM.****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM.**** »</TD></TR><TR><TD CLASS="quote">just go K-series man best route to go no days quiet expensive but worth it my o2</TD></TR></TABLE>
ugh
ugh
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmYrE »</TD></TR><TR><TD CLASS="quote">I dont really want to do with a b16, thought about an h22, but i was curious to kno if a gsr motor will be able to fit into mi bay. what wouold it take for it to happen if possible? </TD></TR></TABLE>
B18C swap is identical to a B16A swap other than the wiring.
p c e g
13
09-29-2012 04:04 AM
Hatch_Back_97
26
06-18-2006 07:44 PM
