help! b16a2 drivers side axle
Re: help! b16a2 drivers side axle
take the halfshaft off, its like 3 12mm bolts and then use a big ****ing hammer. it should pop out. put some type of lube on the splines before putting the new axle back in.
if your half shaft wont easily slide out of the tranny than you may have a problem with your differential. my half shaft came out with minimal effort and went back in with almost no effort. do you have a pry bar?
HGZ
03-08-2005 01:12 AM
