HELP b16a FROM HELL
Ok guys I will try to explian this as best as possible... I have a 94 EG hatch and I just finished putting in a first gen b16a. I am having serious problems with it, i can barley get to start, wont hold an idle for shit, is not drivable. at first i thought it was the timing belt because its slipping a tooth and fucking up the timing, so i changed the timing belt, and it didnt fix the problem same issues. Then i saw it was still slipping, so i changed the tensionr spring and STILL nothing. Ok so i moved on to spark plugs, and changed them, and used a different set of b16 wires. Still nothing. NOw I moved on to the dizzy and it acts like its not getting spark like the ICM is fucked didnt have time to test today, will no tomarro, In addition the timing belt is still actin funny, going tight sometimes and loose others.
HaS anyone had this problem b4, and ideas would be great THanks. |
Re: HELP b16a FROM HELL (Bseriescivic5)
did you check your cam gears cuz my buddy went through 3 timing belts before we realized the cam gear was worn to shit
Are you running the OBDI or the OBD0 B16? cause if its OBD0 you might have a problem with the harness's
well im not sure about the cam gears, i have brand new AEM ones on the way, and as far as the harness goes its fine, b/c the motor was in my buddys 92 EG and ran perfectly, thats y i dont understand this.....?
I had a similar problem with a minime I built some time ago. It turned out to be a bent cam gear.
we will see what happens when i get my new cam gears.
anyone else ever had this problem?
you try switching the TPS and MAP? that may solve the idling problems..
Re: (ej0513)
you're using obd1 ecu, obd1 (grey plug) distributor, and obd1 (grey plug) injectors, right?
converting a B16A first gen block to obd-1 is no fun, but it can be done and made reliable, just have to make sure you get everything. there are more mods needed than just what's listed above, but those are the main ones that would affect starting/idling. |
Re: (nuc79)
whats up
i just had simliar problems with my b16a obd1...if your check engine light is on..go by the jumper connecter (blue connecter with two holes) run a paper clip between the two connecter...tuen your key..but dont turn the key on..long flash means 10...short falsh means 1..like 2 long a 2 short would be 22...if you cel isnt on..mine was a MAP sensor and a o2 sensor |
Re: (LSracing94)
i mean dont turn the car one..and the conencter is by the ecu
yes i know all have been checked, im getting code 6 which is a water temp sensor, whihc i know isnt helping, i need to eliminate some more variables....should have more info by end of week. and yes this swap has been converted to obd1....it was in my friends 92 cx and ran perfectly.
Re: (Bseriescivic5)
just making sure i can still post sorry for the interuption i can assure you it wont happin again my fellow honda lovers
bump
Re: (Bseriescivic5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bseriescivic5 »</TD></TR><TR><TD CLASS="quote">In addition the timing belt is still actin funny, going tight sometimes and loose others. </TD></TR></TABLE>
It runs like that cuz your timing is poopy. Whatever is causing your timing belt to kick out of place isn't good. Either a.) your water pump is messed up and the drive gear bearing is loose or sloppy b.) your tensioner is messed up c.) you didn't route the timing belt correctly d.) your cam gears are loose/worn e.) something is catastrophically wrong with the engine |
Re: (project_mercy)
OK greg thanks for getting the info out there
First off like he said motor ran fine was in accident, and did brake stuff, like TB misc sensors and trans motor turns over fine by hand, w/compression, take out plugs and turns over fine no compression, so INTERNALLY motor is sound as far as cam gears i dont think there bent but who knows as far as the water pump, that could be it the funny part about this whole thing is when my girl wrecked the car (www.hondatwincam.com/dan/ouch) it was fine pulled it put into his car, and we realized the Tensioner one LOSE as if it broke the bolt or something but NOThING is wrong with that, changed them to my spares, spring belt all new, and no avail thanks for the info dan |
anymore ideas guys????
anyone???
Re: (Bseriescivic5)
What were the compression numbers if the compression is good? Sounds like the belt slip caused a valve or two to bend and account for the rough engine and hard to start.
i have no idea what the numbers were.....unlikely that the vavles are bent.......b/c i can advance the timing to hold a steady idle, but no trottle response.....i think it might be the ICM in the dizzy, i think we fryed it.......but just to be sure ill find out the compression #'s
Re: (Bseriescivic5)
We had that same problem with a EF w/b16 swap. Turned out being the cly sensor wires were reversed or in your case could be the cly sensor being bad which is built into the distributor base. If you have a spare or a friends distributor to try that could help.
yeah that could def. be the problem.....will be working on car this week....will let you guys no.
found the problems
FIRST dizzy was 180 out inside were the rotor attaches to cam second ecu died, for whatever reason (lucky i had a spare) Third IM has a fuckin hole in the back of it from the accident like the size of a pencil eraser guess we missed that after the accident, lookin at all the damaged parts to fix, o well car runs good right now for the fact that Timing wasnt set yet (water temp sensor is not hooked up) and the whole in the IM we will fix this week thakns for everyones' input dan |
yeah thanks alot guys, will let you know how everything works out....looks like we are going to JB weld the IM for now, unless anyone here has a spare first gen IM.
ok, car actually runs now, and is driveable, however its slow as shit still obviously b.c the timing is like 20 deg. retarded, prob is im getting code 6 (water temp sens.) and i cant figure out whats wrong with it, the sensor is hooked up and doesnt appear dmg. any input?
