HELP ASAP!! CAR DIED!! WONT START
ok it was running fine when i went to my friends house, i leave 2 hours later and car starts fine and everything.. i stop at a red light after about 5 minutes of driving and my car starts to idle weird.. so when the light turns green, i drove about 100 yards then hit a slight bump, and it just died!! all of the lights in the gauge cluster came on (SRS, Battery, CEL, Brake and Oil) i pressed the gas.. nothing, so i pulled into a parking lot before i lost momentum
i tried to jump start it but that failed and everything was connected right
any possibilities as to why my car would just die all of a sudden??
(i just put an intake on my car so you think maybe i hydrolocked?? i didnt hit any puddles but when i left my friends house i noticed that my car was wet like it rained outside)
Re: HELP ASAP!! CAR DIED!! WONT START (muhaMan)
just because it rained outside doesn't mean you'll hydrolock, especially if it was parked.
what year car is it? engine? any CEL?
all the fluids are in, has gas and oil and everything..
i have 1995 Civic with a D16z6, ALL of the lights in the cluster are on
when i try to start it, itll crank but it wont completely turn on so no it doesnt turn over..
Re: (muhaMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by muhaMan »</TD></TR><TR><TD CLASS="quote">all the fluids are in, has gas and oil and everything..
when i try to start it, itll crank but it wont completely turn on so no it doesnt turn over.. </TD></TR></TABLE>
sounds like an electrical problem. if it was a spark or fuel problem the motor will turn, but not start.
how's your battery? check your alternator belt. i also heard that symptoms like this happen when the ignition switch goes out. something to consider.
Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
how's your battery? check your alternator belt. i also heard that symptoms like this happen when the ignition switch goes out. something to consider.</TD></TR></TABLE>
his car does crank, if its not getting fuel it will crank but NOT start. I would do the basics first, pull your battery out and go get it tested, its free. Then check all connections. I have a feeling its the battery
Re: (mikeycivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic »</TD></TR><TR><TD CLASS="quote">
his car does crank, if its not getting fuel it will crank but NOT start. I would do the basics first, pull your battery out and go get it tested, its free. Then check all connections. I have a feeling its the battery</TD></TR></TABLE>
i was going off the part that he said "so no it doesn't turn over".
either it cranks (that's what we mean by turning over) or it doesn't.
Re: (muhaMan)
don't forget to check you ground cable connections. Also are the terminals on the battery all corroded? If they are, clean them up real good and shiny with a wire brush and clean you cable connections too. Then give it a shot.
later,
robert
later,
robert
Re: (philosofy1)
either it cranks (that's what we mean by turning over) or it doesn't.</TD></TR></TABLE>
who is we ? the honda tech world... refer to turning over as starting, crank means just what it says "crank" and thats it, no biggy either way, I have my lingo and "we" (honda tech) has theirs
Re: HELP ASAP!! CAR DIED!! WONT START (tommy06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommy06 »</TD></TR><TR><TD CLASS="quote">it could be ur fuel relay switch mounted under the dash simple job but expensive part</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er »</TD></TR><TR><TD CLASS="quote">maybe alternator or fuel pump. thats my first guess.</TD></TR></TABLE>
this thread is a week old. i'm pretty sure the OP has the problem fixed.
OrangeBoost
08-01-2006 05:13 AM
ElementX
09-09-2002 02:49 PM
