HELP ON 96 CIVIC
HELP ON 96 CIVIC
OK I'M HERE TO ASK ANYONE THAT MY KNOW THE CAUSE OF THIS. MY FRIENDS 96 CIVIC IS NOT STARTING. I'M SURE NOTHING IS WRONG WITH THE MOTOR THAT IS CAUSING THE CAR TO NOT START. I'VE CHECK ALL THE FUSE ON THE CAR BUT NOTHING IS BURN OR BAD. AS WHEN YOU PUT THE KEY INTO THE IGNITION NO POWER IS ON. YOU CANT EVEN START THE CAR DUE TO NO POWER AT ALL. NOW CAN ANYONE KNOW WHAT MINT BE THE CAUSE OF THIS PROBLEM??? THANKS FOR READING IT MY HELP AN FRIEND OUT.
Re: HELP ON 96 CIVIC
Easy with all caps man.
First of all have you checked to see if the battery is dead? Simple test would be to see if the dome light comes on when you open the door. After that it is a series of eliminations to determine what is wrong.
As mentioned, please turn off the all caps.
In addition, thread titles MUST be subject specific -- you make no mention of the tech problem.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
fuccitzscribs
Suspension & Brakes
06-08-2010 10:16 AM
Jaysun
Acura TL, RL & ZDX
21
09-16-2009 03:47 PM
