help 93 h22 swap BOGGS
93 CIVIC WITH H22A4 swap boggs after 4-5k rpm
it drives fine under 3k rpm, idle fine
so far i clean out the map sensor, i wired up the resister box, clean the injectors, gave it a tune up, still boggs, NO CEL
vtec comes ono but when it kick on it goes slower i cant pass 5k, it'll bogg real nasty
help please
thanks in advance
help please
thanks in advance
Re: help 93 h22 swap BOGGS
Do you know if your Engin was OBD2 or OBD1? the OBD2 does not need a resistor box and could cause your car to run like $hit. I ran into this problem when I did my firs H swap. Obd1 have the gray clips and the obd2 have the black clips.
yes i gave it a full tune up...i change my plugs ran alot better i was able to pass 5 then it started bogging after 6ish..the motor is obd2 in a obd1 car i changed the injectors to obd1 h22 injectors...IDK wat the problem is..irritate the hell outta me..i did every thing i could..an think of...idk what the problem is
i had a similar problem on my old eg it turned out to be the ecu i wasn't getting any cels or anything but once i changed the ecu, tps and intake temperature sensor problem solved.
i rewired my resister box. same problem...i changed my ecu to a p72 problem is slight worse...change to a p13 problem went real bad...chipped p28 does good but boggs after 5500..
i think ima try another h22 throttle body..an see if that does a diff with a diff tps..other than that what else can it be
^ u are correct..tried another tps..problem still exist...rewired the whole injectors..and change the whole dizzy problem went away....damn the h22 was faster then my high comp b20..an gsr...
RiceRocketDave
07-24-2006 06:20 PM
