HELP 1995 DEL SOL (NO START )
Alright so my serpentine belts were squealing on my car, so i re-tensioned them. I loosened the bolt on the alternator pulley ( i also unscrewed this wire cluster in the ribbed outside casing that was making it hard for me to move the wrench. from the body which looked like it was just a bracket, but now i think it was a ground for the wire but i forgot to screw it back in before i cranked the car do not know if that was a problem) But i got the belt tension nice and tight cranked the car no squeal. then the next day i cranked it and the car cranked but i almost felt a wobble from the car (meanwhile that bracket on the wire is not hooked up) so i cranked it again and it kinda started and gave out i thought the belts were too tight i loosened them and now the car wont start it will turn over all you want it to but will not fire up i cant figure it out. the crank sounds a little high pitched but could be wrong please if anyone know what is going on let me know had no probs from this car except for squealing belts
Re: HELP 1995 DEL SOL (NO START )
I checked all fuses no cel lights. There is fuel in the filter and in the fuel return i pulled the spark plugs there seems to be a fair bit of oil on them not a ton and maybe possibly leaking above the plugs which i think in return may have fouled them which in return im going to replace all four and see
