help!
help!
im replacing one of my broken wheel studs and i can't remove my axle spindle nut!
it seems like my tranny is slipping or something because i can barley move the wrench but it move some and i think the axle is turning when i try and loosen it
what should i do?
what should i do?
Re: help! (doodooheadfart)
go to a local shop and ask them to break them free (air tool), then hand tight them down and drive carefully back home. Bring ur gf with ya, it works wonders.
Re: (ccjustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccjustin »</TD></TR><TR><TD CLASS="quote">have someone push the brakes while you hop and down on the breaker bar, that's what I did </TD></TR></TABLE>
make sure you have good pressure in the brake lines i.e. have the car running for a couple seconds so the brake booster works. Then do it. Good luck!
HT Order of Merit
Re: (EG2driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doodooheadfart »</TD></TR><TR><TD CLASS="quote">i can't go anywhere
i have two broken wheel studs
How do you plan on getting the hub out? You will need a slide hammer at the bare minimum.
well my friend is gunna let me borrow his 2 gallon air compressor and impact wrench today so we will see how that goes
if that doesn't work im just gunna get the socket wrench back out and throw a 3ft long ***** wrench on it and start jumpin
alright what happened is that i got an impact wrench today but i didn't even use it because like i said my axel kept on spining
so i put the breaks back on and then i just had my friend push the breaks while i used a ***** wrench on the socket to break it loose
everything went good until the axel puller
u started to PUSH the axel through the hub
so we played around with it alot until we decided that the hub wouldn't break loose no matter what we did
so we started unbloting everything that attaches to the hub so we can push it out of the hydralic press tomorrow
what's an axle puller? when I took my axles off I used a big flathead screwdriver and popped them out of the tranny. then I used my 3/8 extension and a hammer, and banged them out of the hub, (from the outside)
fred92htch
14
08-15-2021 02:54 PM
djcaseanova
11
12-04-2003 04:38 PM
