help...
help...
when i turn on my civic, before it would idle to 3k rpm n gradually go down to 1k within a 2 minute timespan, but recently when i would turn on the car, it would crank for a long time, and the rpm needle would go back and forth between 1 and 2k and then jump to 3k and then back down. while this is happening theres some kick back going on in the exhaust and it sounds like the car is going to die. i replaced the spark plugs thinking that was the problem but i guess it wasnt, any thought on what it can be?
Re: help... (sicky)
well it used to warm up from 3k because my civic has an h22 swap, but yea it is actually the motor, can it be cuz of the ditributor cap, or fuel injectors
Modified by diesel4304 at 8:44 AM 9/26/2005
my car was just doing this...
http://www.ef-honda.com/ben/Badidle.php
it can be a number of things...
run through the steps on that page and you should fix it.
my idle screw needed an adjustment, but more commonly it's your FITV.
There's a little plastic screw inside... the site goes into detail. check that first...
good luck.
good luck.
Re: help... (diesel4304)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diesel4304 »</TD></TR><TR><TD CLASS="quote">well it used to warm up from 3k because my civic has an h22 swap</TD></TR></TABLE>
3k is high for any honda engine including the H. You should idle at 1500 cold, 750 warm +-200.
sevenstar
06-06-2008 11:08 AM
EG6AAARRR!!!
32
06-19-2007 10:57 AM
VTECsound
04-09-2005 04:24 PM
