Help - 00 SI AC Compressor, same as 96-00
I'm looking to buy new AC Compressor for me 00 Si, I found good deals with 96-00 AC Compressor, Would this comp. fit the Si. Any help will be appreciated.
Re: Help - 00 SI AC Compressor, same as 96-00
99-00 Si model uses different A/C compressor, for a DOHC motor. You need to find this one.
The good deals you found for the 96-00 compressors are most likely for the SOHC motors.
but you can make it work, i did it on mine, i believe 1 or 2 bolts won't line up, but as long as you tighten the rest you should be good, i been using it like that and it works just fine.
supadupamikey
08-29-2004 05:20 PM
