Heavy steering
Heavy steering
My non PS EG hatch steers very heavy.. the first couple of degrees turn in is quite smooth, but the rest is much heavier.. bone stock car, even stock wheels with good tires..
Compared to my non PS CRX which was MUCH MUCH lighter even with the smaller steering wheel & bigger tires..
Is that normal or should i really check for really wrong problems in my caster/toe in/out.
This user can set his title.
Re: Heavy steering (Dirk-EG)
How's the camber in your front if you have any?
I had that problem cause my camber/toe was way out of spec. Long and behold after I got that fixed everything was better
Re: Heavy steering (ki3t)
It isnt dropped, so as far as I know it doesnt have any weird camber.. but I'll put it on the allignment machine first, post the results and check back with you guys later.
TeamEK
28
06-15-2010 07:26 PM
Khmi
07-03-2005 09:04 AM
JDMhatchback20
11-17-2004 09:06 PM
