Heater Slider
Heater Slider
I need to figure out how to remove the casing holding the temp slider for a 93 honda civic for i have no heat. I need to fix this but i have no idea how to take it off...and also where are the hoses connecting to the heater core so i can get heat...thanks
Re: Heater Slider (poppycock)
So you have no heat or your slider won't go over to the hot side to open the valve to let hot air out? If it's just the slider, look under the dash and you can fix that in a hurry. Can't help you too much about the heater core, but I do know it's a PITA to get out and fix.
Re: Heater Slider (Ricey McRicerton)
i need to check to see if the cable is connected to the slider...it moves its just i have no heat...thats y i need to figure out where the hoses are for the heater core...to see if the are hooked up right...i have a 93 civic hatch by the way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poppycock »</TD></TR><TR><TD CLASS="quote">i need to check to see if the cable is connected to the slider...it moves its just i have no heat...thats y i need to figure out where the hoses are for the heater core...to see if the are hooked up right...i have a 93 civic hatch by the way
Look under the dash (I know on my EK you can see it without pulling any panels) and there should be a big cable that attaches to a bracket under the dash right in the middle. If it's connected and moving the bracket, your heater core is hosed most likely. Is there any coolant/water in your floorboard?
you may also want to check the valve on the heater hose.
just pop your hood, and look for the heater hose running through the firewall behind the engine (usually on the left hand side)... you will see a valve (almost like a throttle body opening) with a cable attached to it.... check to make sure it's attached.
Risky Business
Re: (Caveman74)
https://honda-tech.com/zerothread?id=661308 - that should have what you are looking for
cadwiese
02-08-2013 11:51 AM
