Heater is blowing cold EJ6 Sedan 97
so overnight my heater got all screwed up somehow the slider worked perfectly when i came out in the afternoon it was hot so i switched it to the cold setting but it doesnt slide all the way not even if you push it i even whent down where the cable is connected and switched it and no way in hell its switching to cold and there is another problem now my heater is blowing cold air even on Heat and full blast i went underneath the hood and even switched it there nothing
how can i fix this what is the problem it worked great one night and the next it was dead cold i really need to fix this because its cold in the mornings hot in the afternoons and cold as S*it in the night time
also one of my rear window defroster cable things that is on the sides fell off what can i use to repair this my defroster doesnt work either anymore because of this for the obvious reason
Re: Heater is blowing cold EJ6 Sedan 97
where the cable is attached to the hoses and stuff? yeah i did that and its still blowing cold when i open that valve it switched the slider on the dash so there is no rip or anything in the cable but idk what the hell is going on
should i follow this DIY http://www.civicforums.com/forums/11...ml#post4271491 or can i just flush it from the radiator?
But don't do any of this until you check the coolant level and bleed the cooling system.
-Check Coolant
-Bleed for air bubbles
-pull out the inlet and outlet hose at the firewall flush with higher preasure garden hose
all these if the heater doesnt work after 1 2 3 hopefully all these will help
is it common for heat cores to get plugged up with debris over the years or is it common for them to break like this
ALSO how does this explain that my slider ont he dashboard doesnt slide all the way over to cold its probalby like this Cold___[]_______________Warm
TheIceMan
02-20-2005 02:20 PM
