heater/air cond. control removal...how
Old 06-29-2003, 04:33 PM
Heinz57's Avatar
Default heater/air cond. control removal...how
hey guys.
the lights that light up my heater controls burnt out, so i wanna replace them. are there any special ways to get it out with out cracking anything? I tried to wedge a thin flat head between the unit and the dash itself, butthe screw driver started digging into the plasic of the dash....thanx guys.
Old 06-29-2003, 04:35 PM
Unceasing Measure
Archidictus's Avatar
Default Re: heater/air cond. control removal...how (Heinz57)
Take the dash completely off and the answer will present itself.
Old 06-29-2003, 05:17 PM
KOALA YUMMIES's Avatar
Default Re: heater/air cond. control removal...how (Archidictus)
In an EG you can remove the Controls without taking the ENTIRE dash out. I dont know what car you have if you have a 92-95 you remove the lower console, the radio, disconnect the cable to the controls (can be a little tricky) that change the temperature. There are 3 screws holding in the heater controls. Two you need your head to be under the lower console to see. Disconnect the two plugs to the controls and pull it out. There are two bulbs in the EG heater controls.
Old 06-29-2003, 07:16 PM
Heinz57's Avatar
Default Re: heater/air cond. control removal...how (KOALA YUMMIES)
hey, koala, thanx. I do have a 92 civic hatch, so that info will apply to me. I'll go try it out. thanx.
Skadaloz
20
05-09-2014 07:00 AM
Brake_Check
12-18-2013 10:29 AM
polyhonda
01-21-2013 05:33 PM
brewski
10-26-2009 06:12 PM
UNKNOWN_MEMBER
01-03-2006 10:03 AM
Quick Reply: heater/air cond. control removal...how
