Heat is Not Working .. HELP
this morning i woke up to go to work, went outside, startd car to get it warm, got ready went outside, no heat coming out, okay figured it wasnt long enough since its cold out, started driving, it got all the way to heating temps. and by now the heat is always working, but nothing but ice cold comes out.. the whole way to work, no heat at all.. last night i was driving the car, it was perfectly fine, woke up an it was like this.. what could possibly cause this?... even on the way home from work no heat.. so it has to be something.. thank you
Re: Heat is Not Working .. HELP
ok heres what happened to my car, the stupid cable that attaches to the heat valve (engine bay) slipped of keeping the valve actually close even though i was putting the controlls to full hot, if you dont know how to find it go under the hodd, trace the coolent hose going into your firewall, you should see a place where the hose meets a valve make sure the metal cable is attached, if its not that idk what it is , as long as the motor is hot you should get hot air.
TheIceMan
02-20-2005 02:20 PM
