Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
- Why Are My Headlights Dim?
Guide to diagnose trouble and recommended solutions
Headlights bright then dim. ELD or "loose" regulator???
#51
Re: Headlights bright then dim. ELD or "loose" regulator???
Try cleaning the ground wires. The connection from the wire to the frame can sometimes become corroded. This corrosion prevents the electrical current from completing the circuit. When troubleshooting an electrical problem the first place to look is these grounding locations. A bad ground can be cleaned with baking soda, a small amount of water, and brush.
Good Luck!
Good Luck!
#52
Good Luck!
Good Luck!
this thread has been dead for 5yrs. Why must you revive it? To whom do you wish luck to? What you post were already suggested back in post 29 and 50. Please do not bring back dead thread.
#53
Because OP has been lost for 10 years trying to fix the ELD on his civic, this guy finally gave him closure.
devils_civic
02-14-2005 03:07 PM
