Headers on a D15Z1?
Headers on a D15Z1?
Who has put headers on a D15Z1?
where did you install the O2 sensor?
did you just relocate your CAT after the headers?
WHat difference did you notice in performance?
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">you'll loose low end and gas mileage.
it is pointless.</TD></TR></TABLE>
Are you sayin there isnt enough back-pressure and you'll loose low end torque?
Anyone have real life experience or numbers to back this up?
HT White Ops
Re: (starlord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by starlord »</TD></TR><TR><TD CLASS="quote">
Anyone have real life experience or numbers to back this up?</TD></TR></TABLE>
When I put a header on my bone stock B18B1, I lost low end, and got an ugly sound out of it, to boot. And a B18B1 is a lot more robust motor than a D15Z1. Your motor is a lean, mean, gas-saving machine. It's been carefully build by Honda's R&D to get the most of it as possible. Bolt-on modding it for power is just retarded. If you want some serious **** about a D-Series motors with VX parts, talk to Bense.
Re: (Eran)
you are right its lean mean gas saver...
ive read most stuff Bense has written on the subject.
so are you sayin its bad to put headers on a honda motor?
HT White Ops
Re: (starlord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by starlord »</TD></TR><TR><TD CLASS="quote">you are right its lean mean gas saver...
No, I'm saying it's minimal gains that aren't free, and come with consequences. Header on stock D-series = crap.
Re: (starlord)
so are you sayin its bad to put headers on a honda motor?</TD></TR></TABLE>
It's not bad on motor. Its bad for gas mileage.
Re: Headers on a D15Z1? (starlord)
Im not sure theres much you can bolt on to a D15Z1 (or any D series) for more performance... Unless you reinforce the **** out of it, add a D16 head and go turbo .
Re: Headers on a D15Z1? (road hazard)
Everything that's been said is total bullshit. It wont hurt your car in any way. It's not going to hurt your power curve. If someone put a header in their car and lost low end, they should have researched more about headers and chose a more appropriate header for their application.
Just get a normal cat and move it back to the stock location for a DX.
Re: Headers on a D15Z1? (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch »</TD></TR><TR><TD CLASS="quote">Everything that's been said is total bullshit. It wont hurt your car in any way. It's not going to hurt your power curve. If someone put a header in their car and lost low end, they should have researched more about headers and chose a more appropriate header for their application.
Just get a normal cat and move it back to the stock location for a DX.</TD></TR></TABLE>
Thank you...you may be a visionary!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by road hazard »</TD></TR><TR><TD CLASS="quote">Im not sure theres much you can bolt on to a D15Z1 (or any D series) for more performance... Unless you reinforce the **** out of it, add a D16 head and go turbo .</TD></TR></TABLE> ive heard that if you put a d16 head on a d15z1 block that it will have low compression.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by road hazard »</TD></TR><TR><TD CLASS="quote">with the d15z1 pistons it does, around 8:1 i think.</TD></TR></TABLE>
you speak the truth...
Go Tigers!
If you're worried about fitment, check the gasket part numbers.
http://www.hondapartsdeals.com.
you'll lose low end power, but gain it up top. d15z1 = no power in high rpms, look at the intake manifold and throttlebody.
If you're doing this for performance, you're better off buying some beer. But if your header is rusting apart, and you plan on getting some other "high rpm D-series" or plan on 'optimizing' your d15z1 then I'd go for it.
If you want power out of D-series, it's going to take a lot of work and a lot of research. If this is what you enjoy, then you're going to have to learn to do some of this yourself. If I were you, I'd look into replacing the gears. scooping up a busted ex trans and putting them in your trans is going to be the best bang for the buck. I must warn you, once you do this you'll start saying "man, this thing has some potential" and your wallet will remain pissed for a logn while. Good luck.
