Head removal b16a2
Old 07-02-2003, 07:42 PM
Poop111444's Avatar
Default Head removal b16a2
Ok, I have to remove the head on my 99 Si with a stock b16a2.
The valve cover is already removed. I marked the teeth on the timing belt with the spot that it sits in on the cam gears. Can i slide off the T Belt and keep tension on it to remove the head instead of completely removing the t belt? Then i can remove the cams and get to the head bolts.
I have a Helm, and i was going to just remove the entire T Belt, but i can't get off the lower t belt cover?! One bolt left, but it bangs into the crankshaft pulley!!!
Thanks
Old 07-02-2003, 07:47 PM
Cory man's Avatar
Default Re: Head removal b16a2 (si_mekanik)
Just loosen the tensioner. It will make it much easier to reinstall the timing belt. HTH
allmtr's Avatar
Default Re: Head removal b16a2 (Cory man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cory man &raquo;</TD></TR><TR><TD CLASS="quote">Just loosen the tensioner. It will make it much easier to reinstall the timing belt. HTH</TD></TR></TABLE>
Old 07-02-2003, 08:01 PM
Poop111444's Avatar
Default Re: Head removal b16a2 (allmtr)
thanks guys.
The tension is behind the lower t belt cover.... From what i understand there are three bolts that hold the cover on. I got 2 of them off, but the third starts to come off, but then it BANGS right into the crank pulley. WTF do i do? I was thinkin about just cutting around the plastic and letting it slide out?
Old 07-02-2003, 11:13 PM
tangb2023
Guest
Posts: n/a
only way is to take out the pully which sucks..
Old 07-03-2003, 01:07 AM
youngkow's Avatar
You don't have to take that cover off. There is a little plug that you can pull off to access the tensioner bolt. Good luck.
atto
01-30-2015 03:30 PM
ED7guy
20
02-21-2013 09:58 PM
jesse0880
12-28-2009 10:52 AM
bOOsTiNSoHcVtEc
08-05-2005 09:28 AM
1point5CRX
12-08-2004 06:17 PM
Quick Reply: Head removal b16a2
