Having trouble taking off my stock muffler!! help
Old 12-19-2004, 02:22 PM
SyDuck's Avatar
Default Having trouble taking off my stock muffler!! help
well, i read that you can spray the hanger with wd40 or some lubricant. are there any other ways? im going to try wd40 right now, ive been trying to do this for 30 mins now, no luck
Old 12-19-2004, 02:31 PM
xCIVICx's Avatar
Default Re: Having trouble taking off my stock muffler!! help (SyDuck)
How about you explain the problem first off buddy... and if the problem is getting it out of the hanger then cut the hanger. they are really cheep to replace! a few bucks. otherwirse just work it out of the slot.
Old 12-19-2004, 03:24 PM
SyDuck's Avatar
Default Re: Having trouble taking off my stock muffler!! help (xCIVICx)
never mind!
the problem was just getting the muffler hangers off the rubber bushings. i ended up using wd40 and poof. magic
Old 12-19-2004, 04:07 PM
crzyfool24's Avatar
Those hangers are a pain in the rear! I usually use WD40 and pull with both hands on each side. Comes off pretty good that way.
Old 12-19-2004, 04:14 PM
Kyles ej1's Avatar
Default Re: Having trouble taking off my stock muffler!! help (crzyfool24)
wd40 doesnt work for me so i used vaseline, works even better. its great at getting things off!
Old 12-19-2004, 04:20 PM
99hatch's Avatar
Default Re: Having trouble taking off my stock muffler!! help (egcoupe)
when you put the muffler back on use some sort of grease and put it on the hangers then you wont have this problem in the future
Old 12-19-2004, 04:28 PM
TSPeed Factory
AzntaggeR's Avatar
Default Re: Having trouble taking off my stock muffler!! help (99hatch)
any type of lubricant works. i just use motor oil when i don't have wd-40.
Old 12-19-2004, 08:11 PM
Yumm Tum Yummm's Avatar
WD-40 works great
Old 12-19-2004, 08:18 PM
Lil Corb's Avatar
unbolt the axle back portion.
Edit: nm u got it
JustDoingMe
04-01-2012 11:11 AM
Spazbaboon
12-28-2006 01:11 PM
Shaguar47
05-11-2006 05:59 PM
JJ2566
07-26-2004 07:24 PM
01TypeR680
03-10-2002 09:58 AM
Quick Reply: Having trouble taking off my stock muffler!! help
