having electrical problems please help!
vehicle speed sensor, alternator and a/c compressor clutch all went out at the same time,any help would be greatly appreiciated.
Re: having electrical problems please help! (taboo948)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by taboo948 »</TD></TR><TR><TD CLASS="quote">vehicle speed sensor, alternator and a/c compressor clutch all went out at the same time,any help would be greatly appreiciated. </TD></TR></TABLE>
coincidence, they all have nothing to do with each other. the vss is easy to replace, the alternator is not that difficlut, but is time consuming, which can be fustrating. as for the a/c clutch, take it to a shop.
It sounds like a PITA, but check everyone of your fuses individually.
Also, they all do use the thermostat ground in one way or another, it may be faulty.
it could also be the main ground line, all though I'd expect hard starting to be mention is that was faulty.
If those check out... unless you know wiring well, take it somewhere to be looked at.
Hondasi88
05-12-2010 08:27 PM
Trac226
08-14-2002 06:33 AM
