have you used this for your home made engine mounts?
Re: have you used this for your home made engine mounts?
no, use 3m window weld. the same stuff used to put windshields in. or just buy a set of energy suspension mount inserts that look nice for about 35 bucks
op, if you want to spend about $14 on 3m window weld go a head. the cheaper alternative way is going to lowes or homedepot and buying there $3 polyurethane window caulk. works the same. they both suit the same purpose. shoot i've heard some people use regular silicone caulking too.
what's up, you don't live too far from me, i used it on my D-series mounts and people think I got a swap when I start the car
btw that window caulking is white.....right?
I would think white caulk for mounts would be kinda ugly. I might try this to repair a busted torqe mount. I will buy white in that case as no one will see it unless there under the car.
Reject Papi
window weld is the only thing i've ever seen being used. never heard about the silicone, but i guess as long as the air pockets are out of it, it should work fine.
they make a black polyurethane window caulking for homes/business too. i think it's about the same grade as the 3m stuff.
im also talking about the black stuff, not the white.
318 Curves, 11 miles
wfocrx
10
10-03-2006 05:53 PM
W O T
10-17-2005 05:23 AM
