Hasport h22a mounts EGH1 or EGH2
I know and have read about the EGH1 kit that hasport makes for our EG's, but right before i was about to purchase it i was told if i wanted the EGH1 or the EGH2 (this being the revised version of the EGH1). I just finished writing a letter to hasport asking them about this as to what kind of revisions where made.? When will it be availible? etc.
Just curious if anyone has heard about HASports EGH2 kit. Asides from the few that i have PMED and talked too
Re: Hasport h22a mounts EGH1 or EGH2 (patastinky)
The EGH2 kit is available now and replaces the EGH1 kit. The EGH2 kit moves the engine about 1/4 inch more to the passenger side of the engine bay allowing just a little more room for A/C and P/S and radius rod clearance. The passenger side mount and bracket are all new and is similar to the passenger side mount and bracket we use on the K-series mount kit for the EG.
Re: Hasport h22a mounts EGH1 or EGH2 (keithg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithg »</TD></TR><TR><TD CLASS="quote">The EGH2 kit is available now and replaces the EGH1 kit. The EGH2 kit moves the engine about 1/4 inch more to the passenger side of the engine bay allowing just a little more room for A/C and P/S and radius rod clearance. The passenger side mount and bracket are all new and is similar to the passenger side mount and bracket we use on the K-series mount kit for the EG.</TD></TR></TABLE>
Can 90-93 Integra Axles still be used? How about the rear engine bracket (92-96prelude still)?
Room for prelude p/s or civic p/s? Room for Civic a/c or Prelude a/c?
thanx
thanx
The Prelude P/S pump with a hose made by welding the Prelude pump end on a Civic hose.
The Civic A/C compressor with a fabricated bracket, which is not available from Hasport at this time. (We are working on the A/C bracket.)
The passenger side Integra axle will not work for sure because the inner joint is not correct. I have no idea about the length on the Integra axles but I do know that axle length is critical on this swap. Hasport has custom swap specific axles that are the correct length.
The rear engine bracket is the same, from a 92-6 Prelude 5spd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithg »</TD></TR><TR><TD CLASS="quote">The Prelude P/S pump with a hose made by welding the Prelude pump end on a Civic hose.
The rear engine bracket is the same, from a 92-6 Prelude 5spd.</TD></TR></TABLE>
Will hasport still recommend that you use a 90-93 accord Intermidate shaft (half shaft) ..?
Modified by patastinky at 6:41 PM 2/22/2005
Anyway you can give up the length measurements?
Re: (kaoss_11)
Supposedly there was failure with the passenger side mount. Thing that I'm worried about most is that when i figure out how to build these axles I'll end up spending more on the parts and pieces than I would just buying the Hasports.
I'm still waiting on a buddy to get back to me w/ measurements and then hopefully I can make an educated guess beforehand and not get stuck w/ $400 in axle parts.
xhondaaccord92x
15
08-20-2009 09:48 AM
brian g
10-20-2007 01:16 PM
StorminMatt
07-27-2006 11:07 PM
