Halo installation on an EG civic help?
Ok, i just picked these up, they are not the 1 piece they are just headlight. It came with a wire harness and instructions on how to hook up the halo part to the parking light, but that is it. I have no clue where this harness goes or how to hook them up. Anyone ever installed these? anything will help. Thanks.
EDIT: Here are a few low qual pics
Modified by h22HatchEG at 3:25 PM 3/18/2006
Re: (h22HatchEG)
From what I can see:
1. Three prong plug (green, brown, silver wires) plugs into stock passenger (I think) headlight bulb socket.
2. Black wire with ring terminal is the ground.
3. Red wire with ring terminal goes to positive on the battery.
4. The two three prong receiving sockets (with the blue and white wires), one receives the driver side three prong socket (coming from the headlight in the pic) and the passenger side three prong socket (also coming from the headlight?).
Re: Halo installation on an EG civic help? (h22HatchEG)
I have the same setup as you. The thick red wires (w/ fuses) go directly to your battery. One of the connectors plugs into your stock headlight harness on the driver side. Then the rest connect directly to the head lights. Black wires go directly to the chassis (ground). And as far as the red & white wires i personally spliced them into the parking light wires so when my parking lights go on the halos do. Also do you have the headlights with the small extra light? if so you can either wirethose into the parking lights or do what i did and wire them into the blinkers so you have more blinkers if this sounds confusing just let me know .. lol im bad at explaining stuff
http://images.h22a.net/lightharness.bmp
hopefulyy you can see that for some reason it wont display on the site
Modified by 93b16hatch at 12:47 PM 3/18/2006
Modified by 93b16hatch at 12:48 PM 3/18/2006
Re: Halo installation on an EG civic help? (93b16hatch)
You sure the (green, brown, silver) plug doesn't go to the passenger stock socket since the harness extends that way? You don't want the harness to go to the driver side and have it come short with the red positive wire trying to reach for the battery.
Hmm where is the headlight harness plug? is it the box right by my headlights, or is it towards the cab of the car?
Oh snap im retarded. I went out there and actually paid attention, and i see lol. So passenger side or drivers side?
Re: (h22HatchEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22HatchEG »</TD></TR><TR><TD CLASS="quote">Hmm where is the headlight harness plug? is it the box right by my headlights, or is it towards the cab of the car?</TD></TR></TABLE>
the headlight harness plug is the same plug that plugs into the headlight bulb.
Re: Halo installation on an EG civic help? (BlueIntegraBoy)
Nope driver side. The long connector with the blue wires goes to the passenger side. And yeh the stock harness is right near the headlights. THe stock plug i guess you could say
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93b16hatch »</TD></TR><TR><TD CLASS="quote">Nope driver side. The long connector with the blue wires goes to the passenger side. And yeh the stock harness is right near the headlights. THe stock plug i guess you could say</TD></TR></TABLE>
Oh ok, I had to take a look at the harness again. It does extend towards the passenger side, but the three prong plug plugs into the driver side harness
I had to plug the bulk of the harness in at the passenger side, since that is where my battery is, and then extended the harness around to my drivers side light.
Wouldnt happen to know what color the wires are that go to the horn would ya? mine are cut and i bought another aftermarket horn but the Haynes wire diagram is wierd and i cant seem to figure out the wires that go to it.
