h23a problems
h23a problems
i have a big problem i have a h23a vtec blue top i hit the dyno and made 195 whp on the dyno the frist time the 2 time i hit the dyno i switch the gas from 93 to e85 gas did the frist pull n made 185 2 pull n made 182 than a 3 pull 133 n it wouldnt pass 133 than i when back to pump gas 93 n redyno again and still dyno at 133 i have never heard of this vtec sounds like its enguageing but i have no ideal everyone that i have asked they have no ideal whats going on so i would like some feed back asap plzzzz n thank u.......
This is what i have done to the motor shaved head port n polish direct port of nos skunk 2 cam gears 3inc exhuast greedy headers 440 rc injectors walbro 255 fuel pump n thats about it......... need help thanks
Re: h23a problems
ok took the head not off but apart on the motor to make sure it wasnt anything messed up n clean everything so i did that n put everything back together n put it back on timing n still nothing plzz need feed back.........
Re: h23a problems
so in 15min you took the head off cleaned everything and put it back together? You know it takes a much larger volume of fuel to rin e85 right?
Re: h23a problems
running from gas to e85, should be tuned for the differenct in gas used, otherwise it isn't going to run right and may cause engine failure
Re: h23a problems
I was wit the tunner when we which the gas n I used his map that he had done right there n than but tge car is running like crap no one knws wat it can b
Re: h23a problems
If the engine is mechanically clean and timing and all is spot on then you have problems with ECU or electrical. Any codes?.. well, your tuner would have noticed a CEL.
Sounds a bit like pre-ignition, where the mixture is combusting too soon during the compression cycle. It will cause the cylinder to heat up even more, like a downward spiral that robs power when you want it.
Then again, you might have ruined the O2 sensor running that E85 through there.
Re: h23a problems
my tuner by passed the o2 sensor so its not that. and everything else looks gd i would like to get this fixed asap plz so if u have any feed back that would help wit this plz post thanks..............
ncturbocivic
09-28-2007 03:37 AM
