h22eg which rad hoses?
Old 07-12-2010, 06:30 AM
farfrumugen's Avatar
Default h22eg which rad hoses?
i was reading the Honda swap guide by Aaron Bonk and it says to use the prelude radiator hoses. says the upper needs trimmed and both need tightened down real tight due to inner diameter differences.
the h22 faq on this sight says to use.1992 Integra LS Upper Radiator Hose -
and 1994 Del Sol VTEC lower radiator hose.
so first off which one is right to use?
also by delsol vtec do they mean the b16 delsol or the d16z6 delsol ?
thanks in advance
adam jeffery
Old 07-12-2010, 09:19 AM
Default Re: h22eg which rad hoses?
up
Old 07-12-2010, 08:41 PM
apparently everyone with eg h22's arent using rad hoses...huh
Old 07-12-2010, 09:02 PM
86elco's Avatar
Im running the b16 del sol lower and a trimmed prelude upper on my ej. Not sure if its the same for your model.
Old 07-12-2010, 09:39 PM
patroneg95's Avatar
man my h22 swap eg dont want to start any more i stop at a stop and it turned off
Old 07-13-2010, 04:55 AM
thank you for responding. it helps alot!
adam jeffery
Old 07-13-2010, 04:56 AM
that sucks, maybe you should start your OWN thread about your problem.
adam
krazycivic4u
05-19-2006 01:05 PM
alleyezonme
08-05-2004 10:05 AM
explosive
11-01-2003 07:58 PM
Quick Reply: h22eg which rad hoses?
