h22a4 swapped ek hatch
ok here is the swap i been working on for a month, beginning pics up til the point i am at right now. im looking for some feedback due to some wireing and sensor issues. i finally got the pics sized right, so check it out and maybe i can get some answers for my wireing
this is the day i got the engine
this is a few picks before the swap[love the scion wheels,JK ]
nice car son, cant wait till u get this up and runin, going to be a BEAST, i hope someone on here can help u out with the sensors and wiring ill also help u out. ill look some **** up for ya.. good luck on the build and hope to see it out and around SOON.
Re: (superhatchbackbros)
yo super hatch bros, find me a obd2a p13 in the area. i made a wireing harness today. all i need is the ecu and 2 teg axles. keep watching ill post some of what point i am up to for ya
Re: h22a4 swapped ek hatch (boosted92hatch)
well this is about were i am at. hopefully ill get the wireing done tonight and swap it in tomorrow.
so my question is for anyone who has done this swap in a obd2 car. i want to keep it obd2. anybody know what sensors needed to be added. the car is already wired for vtec and the knock sensor. but the ckp sensor has a 4 wire plug and the ex harness only has 3. what can i do to get around this. or how do i wire in the 4 wire plug. also i know there is a ckp bypass trick found on ff squad.com but will that work for this swap with the p13, anyone got any answers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92hatch »</TD></TR><TR><TD CLASS="quote">
so my question is for anyone who has done this swap in a obd2 car. i want to keep it obd2. anybody know what sensors needed to be added. the car is already wired for vtec and the knock sensor. but the ckp sensor has a 4 wire plug and the ex harness only has 3. what can i do to get around this. or how do i wire in the 4 wire plug. also i know there is a ckp bypass trick found on ff squad.com but will that work for this swap with the p13, anyone got any answers.</TD></TR></TABLE>
the trick from the website should work, cause what it basicly does, is simulate that the ckp sensor is hooked up. leasts that what i understand from it cause the ckp sensor is only obd2 harnesses/swaps.
nice setup... hope you get the problems fixed but what headers are those? and did you paint them black or did they come that way.
Re: (jdmpower363)
thanks guys, yes its a stock header. the 4-2-1 from the a4. i was lookin for a header that fit directly too the civic exhaust but cant seem to find one. i think i have the wireing figured out. so we will see when i find a 97 -98 p13 ecu. i still need 99-00 fenders for the front conversion too.
Re: (boosted92hatch)
anyone doin this swap, i highly, highly recomend the hasport mounts. didnt have to change anything @ accept the clutch line and the fan was swapped for a slim fan and dual core aluminum radiator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92hatch »</TD></TR><TR><TD CLASS="quote">thanks guys, yes its a stock header. the 4-2-1 from the a4. i was lookin for a header that fit directly too the civic exhaust but cant seem to find one. i think i have the wireing figured out. so we will see when i find a 97 -98 p13 ecu. i still need 99-00 fenders for the front conversion too.</TD></TR></TABLE>
p13's werent made in 97 or 98 just in 96 and not even many were made, that ecu is very VERY hard to come by. I had one at one point and sold it for 270 bucks....
my engine is from a 97 lude sh model and the ecu was an auto p13. they are on ebay all the time but i am not gonna pay 200.00 i will find one for like 100
i just checked and although they do make the p13 after 96, to use it u must also have the immobilizer wired in to start the car. so yes i guess i am looking for the 96 like u had or the 97 up plus immobilizer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. ***** »</TD></TR><TR><TD CLASS="quote">
p13's werent made in 97 or 98 just in 96 and not even many were made, that ecu is very VERY hard to come by. I had one at one point and sold it for 270 bucks....</TD></TR></TABLE>
hey man i just took your advice and bought a obd1 jumper harness. did u have to switch any wires @ or just plug this into your dx harness and then into the obd1 p13. i already added the knock and vtec, not running egr so its been deleted
Just plug and play. I 've got a question for you though, what mounts and axel combo did you use? I did same swap in 99 Ek with HaSport Mounts and Hasport Axels and had binding issues.
Re: h22a4 swapped ek hatch (KidSenation)
hasport mounts with 90/93 accord half shaft and 90-93 integra axles with accord passenger spline that goes into trans. u have to make a custom plate to bolt to the block though. ill try to find a picture and post it. before the 2.4 kit it was running on this same setup and no binding issues
hasport mounts with teg axles and 90/93n accord manual half shaft. no binding issue when in last ek coupe. also u hav to make custom plate to bolt that half shaft to the h22a4 block. wil try to post a pic when i find it
heres the picture of the custom plate that was made to fit up the prelude half shaft to the h4 block. 90-93 teg axles. never a binding issue
