H22a rpms bounce 100-1200 when warm ~ and stalls
H22a rpms bounce 100-1200 when warm ~ and stalls after a min.
idles good upon cold start up. 2 minutes later rpms are 100-1200 bouncing I have cleaned the IACV well I have taken many things off the intake and plugged the manifold holes I replaced map sensor gasket I checked timing ~ its perfect Anybody experience this problem? rpms drops LOW when warm..stalling |
Re: H22a rpms bounce 100-1200 when warm ~ and stalls
bump
it could be a sensor that had to do with being in open loop to close loop where the ecu takes over, ect maby, engine temp sensor
hmm but it idles when cold. I can check the temp sensor.
double bump bump for anybody that has experienced similiar problem
ive been doin research it def sounds like ur tps sensor rite behind the throttle body u can check it with a voltmeter. it should be i think .05 volts with ur car off and throttle closed. the tps will make ur rpms flucate. is it throwing a check engine light?if u call to check for tps sensors they r gonna tell u u have to buy a whole new throttle body cause its riveted in. dont buy a new one for 500.00 bucks just buy a new tps sensor off ebay 50.00 bucks tops take ur throttlebody of knoch the 2 rivets holding the tps sensor down with either a cut off wheel or hacksaw then install the new tps with screws. check ur ecu for codes 1st thts where id start befor buying anything. goodluck!
I have the exact same issue on my H2B Eg. I talked to the guy who tuned my car for me and he told me there was a screw on my IM near my TB that they adjust when tuning the car. My target idle rpm is also 1500 so not sure if that will help you : / I went out started it and played it it until it idled better. I will try to get you a pic if you want..?
