h22a in an eg dx.......what do i need???
i already know that im going to need motor mounts for the swap. but the rest im in the dark.
what type of shift linkage do i use??
what type of axles do i need?? i think its a 90-93 accord halfshaft and integra outers is this true??
wiring for the h22a??
i want to say thanks in advance
Re: h22a in an eg dx.......what do i need??? (hungry4popcorn)
http://www.driveshaftshop.com for the axles.
shift linkage...will come with the swap, Accord or Prelude.
Wiring, just have to extent a few wires, add a few wires. easy.
Look in the hybrid forum for axle info. Or search for topics created by Newman.
if you are buying a 94-95 H22A with OBD1 then here it goes
Mounts - Hasport or HCP
Transmission - All 92 up prelude 5spd will work if you are going ATTS it will require major wiring so don't bother with it
ECU - use the ECU that came with the engine with proper modification to wiring till you chip a P28
Electrical wiring - CX and VX need to convert to 4 wire O2, Non VTEC models need VTEC solenoid and VTEC pressure wiring done. Add EGR solenoid and EGR valve except for VX add air intake bypass wiring and add knock sensor.
Axles - Use 90 up Accord intermediate shaft with 90-93 Integra axles or buy you custom build one
i hope this answers some questions
Guest
Posts: n/a
Re: h22a in an eg dx.......what do i need??? (ace1875)
http://www.hybridgarge.com
http://www.hondaswap.com
you could try searching too. This is only asked like 5 times a day.
1988montecarlos
03-23-2011 08:04 PM
StickyDilJoe
08-29-2002 01:36 AM
