H22A EG 94 CX Vtec not working
So for the past month my vtec has not been working in the EG and today i tried to fix it but i cannot figure out how to pull the cell since hte previous owner messed up the wiring in the whole car completely there is no service connector there is enough oil i checked the little screen on the solenoid thats good too i am going to go to the junkyard and pull out a diffrent vtec solenoid wire the one that goes from the solenoid to the ECU the wire on the plug is ripped but still together idk if that could be the problem but im going to try that tomorrow is there anything else that it could be?
Motor 94 H22A JDM Swap
P28 Chipped ECU
vtec did work prior to a month ago and stopped working and threw a cell
there is a Cel on but i cannot pull it because the previous owner jacked up the wiring badly
P28 Chipped ECU
Re: H22A EG 94 CX Vtec not working
I'm dealing with a similar wiring nightmare. Sounds like something with the vtec harness. Update when you get one from the junkyard.
ScottEK
07-02-2006 10:44 PM
