H22 Swap into 97 EK
Re: H22 Swap into 97 EK (JDMej1Civic)
i cant believe im doing this for you becasue i know you did search. but here you go. ur welcome
http://www.hmotorsonline.com/s...30016
you need everything listed there plus motormounts and axels. motormounts are available at hasport. or you can buy them from the site i gave you. same with axels
Get hasport mounts or the new company arizona racing mounts, I used HCP mounts and i broke two cone mounts already (located on the driver side). upgraded custom axles are well worth it, b/c i took the short-cut/cheap route(accord intermediate shafts with ls axles)and my axles always binds at sharp turns. Upgrade your clutch/flywheel while your motor is out a whole lot easier. Change your waterpump, auto tensioner, timing belt too while it's out of your bay b/c it's almost impossible to change it if it's in your car. i think i used accord shifter plate, a grinder would be a nice tool to cut the whole for your shifter. good luck take some pics.
EightV
12
01-15-2011 12:40 PM
