h22 swap into 93 civ
93 civic dx 4dr...
HMO has a...
H22A 93-00 Complete Change Over
- Motor
- Hydrolic Tranny
- ECU (P13)
- Axles with Half Shaft
- Shifter Cables
- Shifter Assembly
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
then 92-95 civic motor mounts on ebay for like 300...
what else am i going to need to do this swap?
HMO has a...
- Motor
- Hydrolic Tranny
- ECU (P13)
- Shifter Cables
- Shifter Assembly
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
Re: h22 swap into 93 civ (GZR4DR)
Why does he need an engine harness? If you are implying that the JDM engine harness cannot be plugged into a USDM car, you are wrong.
Re: h22 swap into 93 civ (94si94cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94si94cx »</TD></TR><TR><TD CLASS="quote">Why does he need an engine harness? If you are implying that the JDM engine harness cannot be plugged into a USDM car, you are wrong.</TD></TR></TABLE>
Done any JDM H22A swaps recently? Didn't think so. The plugs are on opposite sides. However, he can utilize any of the plugs off the old harness if he so chooses. Hell he can even use his civic harness and modify as necessary, however it wont be plug and play.
it comes with everything already the shift linkage thats the shifter cables, i just recently bought an h22 from them everything was there, they even gave me the right axles for my eg and now my eg has an h22 already running great an strong as hell.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GZR4DR »</TD></TR><TR><TD CLASS="quote">
Done any JDM H22A swaps recently? Didn't think so. The plugs are on opposite sides. However, he can utilize any of the plugs off the old harness if he so chooses. Hell he can even use his civic harness and modify as necessary, however it wont be plug and play.</TD></TR></TABLE>
Just because they are on the wrong side doesn't mean they can't be extended 6 inches to reach the appropriate plug.
ok now are there any extra things that have to be done when doing this swap? someone told me that a mount might have to be welded on or something like that? any help, tips, or pointers are appreciated...
Re: h22 swap into 93 civ (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd »</TD></TR><TR><TD CLASS="quote">93 civic dx 4dr...
HMO has a...
- Motor
- Hydrolic Tranny
- ECU (P13)
- Shifter Cables
- Shifter Assembly
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
what else am i going to need to do this swap?</TD></TR></TABLE>
where did you find this h22 engine?
HMO has a...
- Motor
- Hydrolic Tranny
- ECU (P13)
- Shifter Cables
- Shifter Assembly
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
Re: h22 swap into 93 civ (nekcuttR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekcuttR »</TD></TR><TR><TD CLASS="quote">
where did you find this h22 engine?</TD></TR></TABLE>
http://www.hmotorsonline.com
Jerry31
07-04-2004 11:32 AM
ForcedAccord
12-23-2002 04:33 PM
