H22 questions...
H22 questions...
Would you pay 1300 for an H22 swap with everything but the axles? Well, it doesn't have the Civic mounts or anything, but it has engine tranny ECU.
Its got about 60k on, and the guy who had it before used nitrous. I think it was a 50 shot and he only used it a few times.
Second question: How much total do you think it will be to get it put into a 92 civic? Not including the engine or axle costs, I can get the axles for cheap.
thanks
thanks
Re: H22 questions... (Ajax)
that seems like a decent price. i wouldnt use stock axels though, u have to get custon ones and if your gonna use your stock suspension id swap the front and the rears just cause the rear are longer
Not true. I have a H22 hatch with Autozone(Lifetime warranty) teg axles. I do have lsd and I have launched dozens of times on slicks(7500rpm) at the track. I run BFR drag radials on the street, many launches also. The problem if u are breaking axles is usually the driver, not the axles. You DONT need custom axles...
