h22 in ek axle question
what kinda axle can i use if i swap a H22 in my ek? new to the whole ordeal so any info would be greatly apreciated.. thanx..
Re: h22 in ek axle question (DeviousCTR)
gsraxels, i hear people have problems snappin those axels with an H 22....but i could be wrong about the gsr ...anyone?
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">my thread should help you..
https://honda-tech.com/zerothread?id=983454</TD></TR></TABLE>
drive shaft shop too
Guest
Posts: n/a
Re: (snatch13)
yeah, id just buy custom axles and be done with it. Hasport makes em, DSS makes em, Raxles, Enjo, and I got Gator axles. just be careful you dont order from fast-turbo.com cuz it took stan the entire summer to give me mine.
id go with DSS or Hasport and i believe hapsorts axles ARE DSS ones... somebody correct me if im wrong.
i was thinking of gettin some custom axles too.. just might go ahead and do it..
last question.. i know you have to cut a hole out for the cables and shifter assembly.. my main concern is will i be able to go back to stock or perhaps a Bseries swap if i decide to later on??
Re: (DeviousCTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeviousCTR »</TD></TR><TR><TD CLASS="quote">
last question.. i know you have to cut a hole out for the cables and shifter assembly.. my main concern is will i be able to go back to stock or perhaps a Bseries swap if i decide to later on??</TD></TR></TABLE>
Yes you can go back to stock, just make sure you dont cut the mounting holes for the rod shift linkage.
btw, for axles on a friends h22 ek swap, I used accord(5speed) intermediate shaft and '90-'93 integra axles. No problems as of yet.
tr0n9h
12-21-2007 11:33 AM
AnclyT
02-10-2007 04:42 PM
