H&R Race Springs (integra) will it fit on civic??
* B A N N E D *
hi i just picked up H&R race springs for a integra 94-up i was wondering if it will work on my 92-95 civic si hatchback... because i know the shocks are the same for tokico but the H&R product number is different will it work please let me know!! thanks in advance
Re: H&R Race Springs (integra) will it fit on civic?? (ryan819)
yes they will work... they are also a bit stiffer vs. the H&R race springs exclusive to the civic.
DUDE don't do it. In my experience and recently this other guy on the board (fhnanon or something like that... he has a bus in his sig) the front always seems to sit higher. I don't know if it has to do with the engine weight or anything, but the front sits high. It was like that for me with Eibach pro-kits, and it was even worse for fhnanon using Eibach sportlines.
Jake
Jake
Re: H&R Race Springs (kn1ghtrydr)
too stiff
and yes it has to do with the wight so it will only give you like 1 inch instead of the 2+ from the civic springs. I had them on my hatch. They will hurt you teeth when you hit a bump!
Re: H&R Race Springs (97civicdx)
My Cx is lowered on H&R Race Springs Integra rated and it rides ok it's a little stiff but I got some Koni Yellows coming. The front of the car is lower more than the rear and it doesn't have a swap yet heres a pic of my car
Sorry if the pic looks like crap I used my phone cam to take the pictures.
the front shoould sit higher then the back as everyone has already stated
but if you are going to do a swap anyways you might as well just get those instead of buying two sets in the long run
as for the guy with the white civic your front might be lower then the back due to blown struts or you dont have integra springs?
Re: (ITRacer121)
(ITRacer121) No I don't have blown struts and the part number of the spring are right . Who knows maybe my CX engine is 70 lbs heaiver j/j
Modified by G2AT8K at 6:57 PM 4/12/2003
Re: (G2AT8K)
I used Nuespeed race springs and my car sat exactly like the white hatch. It came down another 1/2 an inch after the swap though, the front i mean. It gives the car a nice nose down look.
thehatchninja
10-18-2003 09:51 AM
