overheating ek coup =(
Old 07-06-2011, 08:11 PM
ef9_lover's Avatar
Default overheating ek coup =(
Old 07-06-2011, 08:18 PM
hyperblu's Avatar
Default Re: overheating ek coup =(
Is the fan kicking on?
Old 07-06-2011, 08:32 PM
Former User's Avatar
Originally Posted by ef9_lover
...put more coolant let it run without cap for like 10 mins air bubbles coming out like a mothafcka.
If this is still happening, then the head gasket is likely blown.
Old 07-06-2011, 08:33 PM
hyperblu's Avatar
Pull the plugs and shine a light down the cylinder... If the piston top is clean and shiney in some spots, your burning coolant...
Old 07-07-2011, 06:19 AM
cjk95delsolsi's Avatar
This does sound like a headgasket issue with bubbles coming out from the radiator. You could do a compression test.
Old 07-07-2011, 07:22 AM
motegicivic's Avatar
First off see if the fan is coming on, either at idle and sit and watch the gauge slightly past 1/2 up should start to come on.
There is a test for gases in the coolant, either get it or have a shop test to see if the head gasket is shot.
Old 07-07-2011, 10:29 AM
fan is kickin in. also i ran it took cap off and now there is a constant bubble flow coming out of it.
Are you saying it is overflowing out of the rad? or just a constant flow of bubbles?
Get a test kit, chances are it is the head gasket.
Old 07-07-2011, 11:30 AM
pityocamptes's Avatar
Did you pull your plugs and check them and the cylinder/piston? If a plug looks brand new compared to the others, and that piston/cylinder also looks nice and shiney you have a coolant leak in that cylinder...
Old 07-08-2011, 04:31 PM
nah its stayn in the radiator. but when i take the cap off then turn it on there always bubble coming out. wen i get back from work 20 mile trip radiator is almost empty have to fill it up.. overflow is fulll idk why its not taking coolant out the overflow
No visible leaks, I am willing to bet headgasket then.
PapiSeeds
09-24-2012 10:16 PM
Ldo
10
01-07-2009 07:42 AM
Harassing Herbs
08-29-2005 02:15 PM
Quick Reply: overheating ek coup =(
