H-Heaven B16 Question
http://www.h-heaven.com has a B16a with a cable tranny and hasport motor mount kit for $1795....Would that go good in a 92 Hatch or would I be better off going with the B16A2???
Unceasing Measure
Re: H-Heaven B16 Question (HatchbackSiVtec)
If you can easilly and correctly install the shifter that comes with the engine (I.E. the cable shifter and cables) then that's a great deal. It works nicely in a CRX, I assume it would work as well in your hatch.
Risky Business
Re: (HatchbackSiVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A Ferio »</TD></TR><TR><TD CLASS="quote">by the time you spend all the money buying the cable-hydro conversion kit, buying/modifying the distributor to work with the OBD1 system and doing a lot of cutting and splicing of wiring harnesses and other random bullshit, you still have a motor that is 10hp less than the one you could have bought and you would have now spent the same money as the SiR2 swap, but are getting less performance</TD></TR></TABLE>
**** the B16A SirI and get B16A Sir2
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">You should just get the Sir2 swap in the first place...don't make it more difficult or costly than it needs to be.</TD></TR></TABLE>
agree
agree
Re: (doublejz)
I'm not sure if you have access to a local jdm engine importer like this one--> http://www.hmotorsonline.com but for 2250 Steve will give you the "complete" SiR-II swap. That means everything you need for your EG. Maybe that H-Heaven place can price match something similar. I know for a fact that the 90-00 Integra shift linkage will work just fine in your EG. Trust me, I tried it plenty of times. For some odd reason the 93 driver side Integra axl works best on EG's as well. Well I hope the best for you.
Re: (BauleyCivic)
werd, y0
werd, y0
Re: (silverEH2)
Meh-- SiR-II for sure. You're not really "saving" money here. First off, you'll have to convert the SiR to OBD-I-- being that it's not hard per-se, but it just sucks. And the cable tranny? It's not worth cutting holes in your car for an inferior product that has more miles on the engine.
Save the $500.
Save the $500.
Convert
08-20-2008 05:10 PM
10secondr33
07-12-2001 10:15 PM
