guage cluster isn't working... and so are my turn signals
my guage cluster isn't working.... the lights work.. but the rpm, speedo, fuel, and water temp don't work... can anyone give me suggestions? my turn signals also don't work... i check the hazard fuse under the hood, and it was blown... so i put in the same size amperage in it and it keeps on blowing on me...does anyone know what the problem could be??
Re: guage cluster isn't working... and so are my turn signals (cxhatch02)
could you elaborate??
what type of cluster?? car?? do you have those damn indiglo gauges??
has it worked in the past?? or did you buy it off ebay or something???
Re: guage cluster isn't working... and so are my turn signals (Jswpstdoff)
its a 92 hatch.. i put in a 95 LX guage cluster with the tach.. it worked for a while then i just quit.... i don't have those indiglos and i bought it from a repectable local junk yard... and the turn signals still don't work.... any ideas... thanks
New User
You should try to find out what's making the hazard fuse blow. Look for any areas where a wiring harness is frayed and causing a short to the chassis.
Whatever you do, don't just put in a high amp fuse in there, but I'm sure you knew that already.
I changed my cluster on my 92 hatch too and then my turn signals would not work. I checked all fuses and even changed the turn signal relay. I read all the posts I could find on the subject and it ended up being the plastic trim around the steering wheel and ignition. When I put it back on it pushed the conector plug out of the turn signal arm.
The is also a single black ground wire that should be hooked up under your dash! Near the cluster.
Hope this helps. Just another thing to rule out.
Re: guage cluster isn't working... and so are my turn signals (mercury)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mercury »</TD></TR><TR><TD CLASS="quote">You should try to find out what's making the hazard fuse blow. Look for any areas where a wiring harness is frayed and causing a short to the chassis.
Whatever you do, don't just put in a high amp fuse in there, but I'm sure you knew that already.</TD></TR></TABLE>
don't put a high amp fuse in there, ever!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mercury »</TD></TR><TR><TD CLASS="quote">You should try to find out what's making the hazard fuse blow. .</TD></TR></TABLE>
If it isn't plugged in or the fuse is blown turn signals don't work, kinda retarded.
Re: guage cluster isn't working... and so are my turn signals (Gunns)
thanks.....i'll check those.... you might actually be right on the ground wire under the dash near the cluster.... thanks for the help..... and no...i won't ever put on a bigger fuse!!!
i replaced the relay with another one... it worked for like one day then it quit working again.... any more ideas?? ground wire some where???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxhatch02 »</TD></TR><TR><TD CLASS="quote">my guage cluster isn't working.... the lights work.. but the rpm, speedo, fuel, and water temp don't work... can anyone give me suggestions? my turn signals also don't work... i check the hazard fuse under the hood, and it was blown... so i put in the same size amperage in it and it keeps on blowing on me...does anyone know what the problem could be??</TD></TR></TABLE>
I'm having the same problem. Only my hardzard fuse is not blown.
akcapr
11
02-27-2011 09:55 PM
shivic
10-28-2010 10:56 AM
EGed up from the seat up
03-04-2009 04:13 PM
