gsr wiring question
gsr wiring question
whats up guys i just got my 94 gsr engine running and it feels like a d16
if i wire up the secondary butterflies would i feel a signifcant change in low end power or is that how the gsr are suppose to run? also i am running a ls hydro tranny with this motor could this be the prob? this motor is an a 92 civic si and im also using gsr wire harness and a p72 ecu. THAnx for any replies in advance
Re: (moz92)
hmmmm now thats weird the gsr should still feel stronger with the ls tranny then a stock ls... maybe theres something wrong with the motor where did you get it from? miles?
your butt dyno telling you it feels like a d16 isn't an accurate measurement of the power of the motor. there are alot of factors that will make this setup bad. ls with ls tranny, ls motors have more torque that gsr motors so that is going to tell you butt dyno you are accelerating slower. a ls tranny is meant for gas mileage imo and nothing more. that tranny should not be on any car that is being used for performance.
Location: Land of the Hillbillies and Shotguns, Ontario, Canada
Re: (envee)
did you check compression of the motor first? Seafoam it, clean the throttle out, check the spark plugs, cap and rotor etc.
i got this motor from password jdm and compression was fine, so i think . i saw them performin a compression check and all cylinders read 240. are those numbers wrong? i looked online and this is what i found. they also said the engine had aorund 35k. this is my first time buying an engine. i tried to research as much as i can before i bought the engine.
