GSR or Type R Block?
having a little bit of trouble on trying to figure out what to do..maybe you guys cam help me out...
right now i have as setup in my car is
b16 head
gsr block with type r pistons on it
now my question is that i have a good chance on getting a type r block
is it worth getting the type r or staying with what i have now...
i wanna go with the one that will give me more power and what not
any help will be great thanks in adance
b16 head
Re: GSR or Type R Block?
If you look at the front of the block, right above the oil pan, on 96 and newer blocks, there will be a green VIN plate. If it's missing, it's a 94 or 95. Or when you change your oil, if there's a silver can thing between the block and oil filter, it's a 94 or 95. It's not worth swapping the blocks out for that, but given the choice, it's a little better.
btw I heard if you put a ls you will get higher compression a bit. Not sure thought....help me out on this on guys if so
An LS crank will up compression about 1/5 point. The changed geometry is going to affect it more than the compression. And as for the displacement, it's only like 2% difference also.
It's late, I am having issues typing. People need to do more reading on this stuff before asking questions. People aren't going to spoon feed answers for everything. Someone has to do some thinking and figure things out.
TRIAL USER
b16 noob
I have a question and am new to honda tech i have a b16a2 in school and am looking to rebuild for high rev looking to push high 12s on thae track on a stock block head job valve job main bearings do not what kind rod or pistions to use can some one help me out and guide me
Re: b16 noob
An LS will up compression about 1/5 point. The changed geometry is going to affect it more than the compression. And as for the displacement, it's only like 2% difference also.
dude HT is ALL about building and high rev so search. like thumper64 said "People need to do more reading on this stuff before asking questions. People aren't going to spoon feed answers for everything. Someone has to do some thinking and figure things out."
go on all motor and check it out or ask question there
Crazy Honda Guy
He definitely speaks the truth. if you can find a 94 or 95 gsr go for it! You're definitely choosing the right blocks though. Stock block girdle and great rod to stroke ratio ftw.
I know 100% that the pistons are stamped p73. so instead of the p72 that is stamped on the gsr's, what is stamped on the c5 motors?
Crazy Honda Guy
Yes, a Integra Type R has it's own pistons, rods, crank, ect...thats what makes it a type R, but the BLOCK is the SAME....get it???!!
Do i have to out to the garage to take a pic?
people should just use google instead of starting these type of threads
All you people reading this thread right now. Listen to Deetz. He has more knowledge then everyone who already posted here..
Crazy Honda Guy
My JDM ITR block is stamped P72 on the back. I know everything else is stamped P73 but I think Honda just made it easier all together over there both GSR and ITR have B18C and both have P72 so they just make 1 block and change internals, head, and other things... atleast I hope because that means I have a motor to inspect if ITR are stamped P73
Crazy Honda Guy
My earlier posts were regarding the engine block cast and stamping
Here's what i could find on rod stamping
ok ok sheesh calm down here. maybe your right cuz my buddy always said they are stamped p73. then by looking at a b18c5 with a black valve cover and no headers or IM, how can you tell its type-r(without looking at the b18c5 stamp)?
btw I see ppl mentioning b18c. As much as I read b18c is jdm gsr and b18c5 is type-r cuz ppl say that b18c is jdm type-r
