GSR throttle body on AEBS intake.. janky throttle cable??
like the title says..ive got an aebs intake on my gsr ..(w/ stock gsr throttle body) ..now my cable is standing straight up! now i cant use my front sway bar because the cable is in the way ... is there another way of re-routing
my cable..or do i need to swoop up a type R or b16.. any info would help.. thanx -https://i203.photobucket.com/albums/...ic2motor-1.jpg |
o ya ..dont mind the messy engine bay.. that dirt round my timing belt is from portland International raceway's burn out pit.. you should see my alternator!! its no longer silver..its yellow..
Your picture isn't working, and I don't understand how a throttle cable can prevent the use of your sway bar, or do you mean strut bar?
you need an LS, B16a, or type rotor for your TB, its the thing where your cable connects. you will have to make a bracket for the throttle cable to attach to IM
gl |
Re: (DrewMD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrewMD »</TD></TR><TR><TD CLASS="quote">Your picture isn't working, and I don't understand how a throttle cable can prevent the use of your sway bar, or do you mean strut bar?</TD></TR></TABLE>
ya.. strut bar..thanx for making that corection also if any one can show me some pictures, or exaples of what people have done it would be helpful.. welding new brackets, extra.. |
nice setup
Re: (jasony0630)
thankx---- bump
there's no point to posting a picture, cause you can just look at any type R or b16, thats what you need.
you need the attachment from an LS/b16/type r , i also heard that the same one from a d series will work, but i've never tried it so... i dont know the proper name for it, but its the goldish attachment that your throttle cable connects too, its held on by a bolt and has a spring under it, attach all of that, route your throttle cable the right way, and you'll be set. i dont even see anywhere on your manifold to mount a cable bracket.....so you'll have to mock something up, i'm sure others have done it. |
did you use the new throttle cable bracket they included with the manifold?
get a integra type r throttle cable and throttle cable bracket and i bet it will fix your problem
Re: GSR throttle body on AEBS intake.. janky throttle cable?? (jus_spooln_wicha)
i went brain dead reading all these answers, let me try. To fix this problem you need and itr (or equivalent.. ls, b16) tb pulley, throttle cable, and bracket (that bolts to the manifold top front).
i have the same manifold yet to be installed on my gsr, any comments on its performance? d |
I have the same manifold use the bracket that came with the manifold and a new throttle cable from a Teg
Re: (CO$T)
switch the spring thing on the TB
*Yea I know the spring thing https://honda-tech.com/forums/images...s/emsmilep.gif |
Re: GSR throttle body on AEBS intake.. janky throttle cable?? (daver)
daver.. out of all the bolt on that this engine has on it..this intake was the best $100 i spent.. i didnt have any dyno numbers done..but i noticed a huge impact on hp then stock .. also i bought this used so it didnt come with a bracket..
thanx guys for all the comments..ill just rob an LS at my work and see if i can get it to work.. |
