GSR Throttle body and a 95 honda civic
Old 12-02-2003, 03:28 PM
reward_1000's Avatar
Default GSR Throttle body and a 95 honda civic
Wondering if a Gsr throttle body will fit my 1995 civic 1.6 VTEC motor or not. If not is there a good worth while throttle body that will fit.
Old 12-07-2003, 07:23 AM
Default Re: GSR Throttle body and a 95 honda civic (reward_1000)
Yes it does work did it on saturday took all of maybe 30-45 minutes. All that you have to do is switch the linkage plate and if you have an automatic trans you need to drill out the trans cable bracket. You also have to use the Civic idle control valve.
Old 12-07-2003, 11:01 AM
blackeg's Avatar
dude- its very highly recommended to port out the intake manifold by the throttle body. you need to for flow reasons and to make sure that the actual throttle plate doesnt get stuck on manifold cause its smaller. but yea it bolts up- so does most other b series tb's. i have an integra ls throttle body on my 93 ex and the manifold was ported out to match the ls gasket size.
Old 12-09-2003, 04:45 PM
Default Re: GSR Throttle body and a 95 honda civic (blackeg)
Well my intake bore is perfect and the gasket size was the same as the intake throttle bore. I am an ASE mechanic and know to check these things, I had my Certified Honda fried give me the idea to do this.
Gsrsi
12-04-2011 03:04 AM
nitrofish420
11-27-2007 12:52 PM
BOOSTED_JDM_DB8
04-13-2006 02:42 PM
tegSB85
11-17-2005 05:50 AM
goula SOS
06-24-2003 02:53 PM
Quick Reply: GSR Throttle body and a 95 honda civic
