gsr sway on an eg?
gsr sway on an eg?
would i need the lca's to get the rear sway on my hatch or do they bolt on to the gsr's body stock>?
[Modified by madeinjapan, 7:10 PM 1/22/2002]
Re: gsr sway on an eg? (madeinjapan)
I looked under the back end of my '93 dx this morning. I see holes for the mounting brackets (where the bushings are). I didn't check to see if the welded-on nuts are present on the inside of the subframe, though.
However, integra control arms *are* required for the endlink attachments.
However, you could also get an aftermarket swaybar that attaches to the shock bolts. I believe suspension techniques, ground control, and progress bars attach like that.
-Mike
-Mike
Re: gsr sway on an eg? (grippgoat)
thanks. so i would need the lca's to use a gsr's sway bar....i was just trying to get a rear sway for cheap. my other option was to buy a skunk2 sway..
Guest
Posts: n/a
if you have a cx hen you are going to need the lca's but if you have any other than you will not and it wwill bolt right up
saveacivic
Northwest (Sales)
08-17-2010 09:22 PM
-Whitey-
11-08-2002 08:07 PM
