gsr swap wireing ????
I have an obd2 gsr motor and a 93 civic ex.... Can I use an obd2 civic ex engine harness would that plug in to my 93 civic ex without modification? I have a skunk2 manifold so I dont need an IAB . Yes I searched and didint find exactly what I was looking for.
Thanks in advance Jordan
Re: gsr swap wireing ???? (Jordanwma53)
if the gsr is complete with the original wire harness, you can drop it in and use a obd1 ecu. then you have to wire up up the knock sensor and iab.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordanwma53 »</TD></TR><TR><TD CLASS="quote">doesnt the the ex civic with the d16z6 stock single cam motor that come with the car have a knock sencor on it???</TD></TR></TABLE>
no
no
Former Moderator
Keep the GS-R engine harness and it will plug right in - an OBD2 Civic harness won't work at all.
If you keep your 93 Civic harness you'll have to reiwre the distributor to a two-plug type, replug the injectors or run your Civic ones, find an OBD1 alternator or swap out the voltage regulator from the OBD2 unit with your Civic's one. It sucks, but it's not impossible.
Just like the guy said earlier - wire up the knock sensor, but hell if you run a programmed P28 you won't even need that either.
No a D16Z6 doesn't have a knock sensor, nor does the stock P28 ECU for it even look for it.
the OP is asking if he can use an OBD2 civic ex harness and NO you can not. OBD2 civic harness's are one piece while your 93 civic is a two piece. you're going to want to use the original harness off the gsr to make this work.
Former Moderator
Re: (wakeboard_dude5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wakeboard_dude5 »</TD></TR><TR><TD CLASS="quote">the OP is asking if he can use an OBD2 civic ex harness and NO you can not. OBD2 civic harness's are one piece while your 93 civic is a two piece. you're going to want to use the original harness off the gsr to make this work.</TD></TR></TABLE>
That's why I posted this above you:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Me 5 minutes before you »</TD></TR><TR><TD CLASS="quote">Keep the GS-R engine harness and it will plug right in - an OBD2 Civic harness won't work at all. </TD></TR></TABLE>
Former Moderator
Re: (HondaPartsHero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero »</TD></TR><TR><TD CLASS="quote">just use your harness and run the wiring for IAB and knock</TD></TR></TABLE>
I'm not trying to be an ***, but he clearly stated in the first post that he already has a Skunk manifold, and doesn't need anything IAB related.
slowB20ej8
05-24-2008 11:24 PM
98ej8coupe
01-28-2008 09:05 AM
