Gsr Swap Need???
im planing on putting a gsr swap in my eg what are all the gaskets and fluids that i need
Re: Gsr Swap Need???
Is it a complete swap, why would you need gaskets? Maybe a exhaust manifold gasket, coolant, Honda MTF for the transmission, and I would change oil and filter.
3 quarts honda MTF, 4.25 quarts 5w30 oil, 2 gallons antifreeze, 2 gallons distilled water.
Don't need any gaskets unless you want to replace them. If so, you'll need whatever gaskets you feel like replacing. |
Also a muffler bearing so you wont get any exhaust leaks :)
Don't forget the kanuter valve. It is very important.
Originally Posted by es01civy
(Post 41737919)
http://kalecoauto.com/index.php?main...products_id=10 It might also be time to change your clutch belt, so don't forget to check that. |
yeah its a complete swap and getting a new exhaust system as well
want to change trans fluid also any one know where to get shifter brackets,bushings |
Originally Posted by Civicfanatic_09
(Post 41738216)
You are going to need the gsr rear tranny L bracket for the motor mount.
Energy suspension makes shifter bushings that are polyurethane. That's what I would use if I was you. Here is an Ebay link to red ones they are like 10 bucks plus shipping.
http://cgi.ebay.com/ebaymotors/Energ...Q5fAccessories |
(Post 41738216)
everything you need can come from a integra
(Post 41738216)
