GSR rear sway on my ek
I have a 97 civic ex. The guy is selling a GSR rear swaybar with the endlinks. What else do i need to put it on, and from what car? Will I be able to use the gsr endlinks? Also do my stock rear lca's accept the bar? Will I have to do modifications for it to clear my stock exhaust?
Re: GSR rear sway on my ek (turnsignalandy)
your stock lca's will work fine if they have the hole already in them from the factory. I had to drill out my passenger side LCA to install my sway bar for some reason, but the driver side did not have to be drilled. You will need a beaks kit and probably the 99-00 si endlinks
You will need:
52317-S04-000 BRACKET, RR. STABILIZER (QTY: 2)
52321-S04-003 LINK ASSY., L. RR. STABILIZER (QTY: 1)
52320-S04-003 LINK ASSY., R. RR. STABILIZER (QTY: 1)
52315-SR3-000 BUSH, RR. STABILIZER (QTY: 2)
52308-S04-000 HOLDER, RR. STABILIZER (QTY: 2)
95701-08018-08 BOLT, FLANGE (8X18) (QTY: 4)
93403-08020-08 BOLT-WASHER (8X20) (QTY: 4)
90212-SA5-003 NUT, SELF-LOCK (10MM) (QTY: 2)
90002-S10-000 NUT, FLANGE (10MM) (QTY: 2)
You can use your stock LCAs
Re: GSR rear sway on my ek (BlueIntegraBoy)
I read somewhere that the guy had to modify some parts to clear his exhaust, case that bar would have went straight through it.... is that true
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">You will need:
You can use your stock LCAs</TD></TR></TABLE>
how much will all that stuff cost me, and can i get it at the local napa's? Also anyone have a diagram with the swaybar and how it bolts on?
expletive me. I just got the bar, it comes with the bar, enlinks with nuts and bolts.... bushings (29 on diagram) and the D bracket around the bushings. What else do I need? Where can i get some si endlinks? Can i get the nuts and bolts to mount the d brackets from a home depot store?
SOB am i screwed? Lookin around in the internet and the cheapest si endlinks i found were for 30 a piece!! I pain 50 of for the swaybar........ anyone know where i could get some cheap endlinks?
