gsr rear seats in an ek hatch
Old 11-06-2003, 04:50 PM
official honda whore
EARLdaSQUIRREL's Avatar
Default gsr rear seats in an ek hatch
how do you put gsr rear seats into an ek, my friend has a set and i told him i would find out how to put them in and i would help him, any help is appreciated
Old 11-06-2003, 09:56 PM
Default Re: gsr rear seats in an ek hatch (coptzer)
anyone???
Old 11-06-2003, 10:11 PM
TurboBumblBee's Avatar
yes they fit.. you need seats out of a 2 door integra
Old 11-06-2003, 10:18 PM
VX
VX's Avatar
C'mon man, you've been here long enough to know better.
But I'll help ya out this time:
https://honda-tech.com/zerothread?id=100886
https://honda-tech.com/zerothread?id=258047
https://honda-tech.com/zerothread?id=268275
https://honda-tech.com/zerothread?id=291319
https://honda-tech.com/zerothread?id=330128
https://honda-tech.com/zerothread?id=449032
Old 11-07-2003, 02:04 PM
yea, well i searched and got the same links that you showed me, and none of them had any worthwhile information, the info was pertaining to gsr seats into coupes or sedans, and the ones pertaining to ek hatches just said they had them resting and they had no installed them properly
so again, is it possible to put the gsr rear seats into an ek
the gsr rears have lil dollies (rods, pins whatevr) and the ek seats have brackets that bolt to the seats?
how is it possible to get the gsr rear seats to be functional in an ek hatch??
Old 11-07-2003, 02:36 PM
cre18's Avatar
Default Re: (coptzer)
YES , it is possible to put gsr coupe rear seats in a ek hatch. i have gsr leather front and rear seats in my hatch
First, off the bench will fit and be bolted down to the frame using the 2 tabs under the gsr bench. the back of the bench is held down once you stick the seat belts through. when i did my rear seats swap i noticed that the bench didn't have as much cushioning underneath the seats like the stock ones, so i ended up throwing some towels under the bench for added cushion and it raises the seats up a little to fit more snug. also, be aware that there will be a gap on either side of the gsr bench once installed. there is nothing you can do about it, but i hid mine by putting some black stereo carpeting in between the gap so it's not as noticeable.
the rear back portion is a little more time consuming because if you've already noticed the gsr back section does not bolt directly into the ek. what you need to do in order to make the backs fit perfectly like oem is swap the skins. what this means is, take your stock ek backs and start cutting the "o" rings all along the perimeter that hold the cloth onto the seat frame. do the same to the gsr seat backs. carefully take off the existing seat covers from each frame and swap one for the other. the grs back will fit on the ek frame. once, you have swapped the skins, use zip ties to reattach the material to the frame, don't worry the rear cargo cloth will cover all the unsightly zip ties. then reinstall your seat backs. using the ek back frames you'll notice that the seats will fit and lock just like stock. good luck
i'll try and post a couple pics later
Old 11-07-2003, 02:38 PM
thanks alot man, just what i was looking for
Old 11-07-2003, 04:49 PM
cre18's Avatar
some pics of what the finished product looks like
Old 11-07-2003, 10:17 PM
thanks alot i appreciate the help
Old 11-18-2003, 03:05 PM
Axemurderer23's Avatar
Default Re: (cre18)
dude coptzer was writing that for me, your directions were awesome, everything went as planned, Thanks again for the directions
Old 11-18-2003, 03:55 PM
Sasebonian's Avatar
To help get rid of that gap on the sides there, you can use the bottom seats from a 4 door integ, but it's not necessary.
Old 11-18-2003, 04:35 PM
cre18's Avatar
Default Re: (jayb98ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayb98ek &raquo;</TD></TR><TR><TD CLASS="quote">dude coptzer was writing that for me, your directions were awesome, everything went as planned, Thanks again for the directions</TD></TR></TABLE>
good to hear, glad the install went smooth
post up some pics of the finished project
Old 11-18-2003, 04:39 PM
Default Re: (cre18)
will do!!! thanks again
Coup3y 17
12-26-2009 06:40 AM
grandam
09-06-2007 04:17 PM
myek96
10-27-2006 07:31 AM
Quick Reply: gsr rear seats in an ek hatch
