gsr radiator fit Si?
Re: gsr radiator fit Si? (b16ej1lsd)
what about a gsr koyo radiator in an ek w/b-swap and no a/c? do i still have to fabricate mounting brackets?
btw just asking because a half-size rad cost as much as a dc full-size, so might as well get the better cooling one.
Modified by bow tie at 6:41 PM 4/17/2006
Re: gsr radiator fit Si? (bow tie)
I have a integra radiator in my ek with a gsr swap.I just removed the two a/c brakets that are on the lower radiator support(you can drill the welds out or use a cut off wheel).Then remove the one radiator tab closest to the drivers side(It's the one on your right when looking down at the front of the radiator support.And messure the length of the bottom tabs on the teg radiator and weld or screw the removed radiator tab back to the lower radiator support.And for the top I just got creative with the tegs top mounting brkts and make them work by drilling some holes in the upper radiator support and used a bolt and nut to fasten the brkts on.Or make some up to work.Hope this helps.
aasaa666
10-22-2007 08:15 PM
